fiulala
5 V pulse board stm32f407
  • February 19, 2015
  • 543 views
Posted on February 19, 2015 at 16:28
Hello, i want to generate a periodic pulse of 5V into a pin using a TIMER. Has someone a code similar to this?
Thank you
#timers #stm32f4 #stm32f407 #discovery
February 19, 2015
Posted on February 19, 2015 at 16:41
Use standard timer code, pick an FT pin, set it in OD mode, and pull to 5V externally.
fiulala
fiulalaAuthor
Posted on February 23, 2015 at 13:46
Got it! Thank you clive. One more question: how do I have to configure the timer if I want to make for example 10 pulses and then stop. Using Counter Mode Down maybe? How should the maín look like?
Thank you
