BLi.0
September 13, 2018
1000 mbps ethernet PHY transceiver
  • September 13, 2018
  • 1254 views
Hope someone can help me. I try to construct a STM32H753 based control module that will communicate with other modules in the network through a 1000 mbps ethernet port, that is a system requirement. How can I connect STM32H753 with the 1000 mbps PHY chip?
Thank you!
Bryan L
    waclawek.jan
    You can't, the STM32 don't have GMII/RGMII.
    OTOH, what would be the rationale for such a requirement? The STM32 hardly can provided a sustained gigabit stream, and 100M devices can merrily coexist on gigabit switches, can't they?
    Jeroen3
    Senior
    September 14, 2018
    If the device must have gigabit support, you can go for a higher performance chip, or add a gigabit switch IC in between.
