DMazz.1
X-NUCLEO-IHM07M1
Is there an example code for start with this kit?. I have tried all code proposed(speed ramp with potenziometer) in STMCW but no one works for me, instead the motor profiler works so i think the harware is OK.
I created the project in STMCW ,i generated the code in cubbeMX and finaly i opened CUBEMXIDE for compile and download the code on board, but like i alread say the motor do not moves.
I hope in any kind of help.
Best.
Claire O.
Claire O.Best answer
I can't see your picture... anyway, no problem if you have the pack.
How about checking with this video:
https://st-videos.s3.amazonaws.com/Getting_started_the_NEW_Motor_Control_Nucleo_Pack.mp4
It explains how to start the motor with your kit.
Let me know if it helps you...
Claire
Claire O.
Hello DMazz.1,
I am not sure I understand what is your set up... X-NUCLEO_IHM07M1 is your power board, but what is the control board? Are you using the P-NUCLEO_IHM001 kit with the small bullrunning motor?
Thanks,
Claire
DMazz.1
DMazz.1Author
Yes this(See the picture below): But at now i'am not able yet to build or implement an example code provided from ST. Where i am wrong?
Best reguards and thaks for the response.
Claire O.
Claire
Laurent Ca...
Senior III
Dear @DMazz.1​
Does the @Claire OKU​ 's answer solve your problem?
Best regards
Laurent Ca...
Laurent Ca...
Senior III
Dear @DMazz.1​
As you do not answer, I guess you don't have to solve this problem anymore, therefore I consider this thread closed.
If not, feel free to reopen it by posting a new answer.
Best regards
Laurent Ca...
