SSubr
X-CUBE MCSDK FOC Firmware related issue
I am having stm32f3 FOC firmware. I downloaded it from st website as X-cube MCSDK full version. But, even after inserting all my header and source files, the code is not working. anyone help me whether i have to make any change in given foc firmware to my microcontroller STM32f302R8. I want the complete procedure.
help me !
Claire O.
I can suggest you to check the video to help you to get started: https://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-expansion-packages/x-cube-mcsdk.html#
or to check the application note: https://www.st.com/resource/en/user_manual/dm00484271.pdf
Then if you need to modify the code , you can rely on the user manuals and the following AP notes: https://www.st.com/resource/en/application_note/dm00505156.pdf
The procedure is the same for the Full version.
If you have still problems, please don't hesitate to send us more details.
Best regards,
Claire
SSubr
SSubrAuthor
sorry claire, I generate codes using st workbench and after then modify using stm32cubemx, but still it shows some problem in arm_math.h header files problem in arm_fir_f32.c. Arm fuctions shows problems. can you please help me regarding this.
phuocnguyenhuu96
Hello.
The tool you downloaded was XCUBE-MCSDK or XCUBE-MCSDK-FULL. If FULL, please give me the tool at mail phuocnguyenhuu96@gmail.com. Thanks so much.
Laurent Ca...
Senior III
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
