EDokm
Working with multiple charts in the dashboard.
How can i add multiple charts to the dashboard? I want to use at least 2-charts in the dashboard, and monitor some variables (not an array) on a chart while some other variables (not an array) on a different chart. I have seen one chart + gauge(s) examples a lot. But all I need is to use two or more charts in the dashboard.
    stephane.legargeant
    Hello
    It is possible to have multiple charts.
    The flow can either have 2 groups of variable, one for each chart,  or one group and then filter the data sent to each chart.
    Please, read this wiki page to have more details : How_to_filter_or_route_variables
    The examples show one chart and one gauge, but it is also possible to have multiple charts.
    I would suggest to use the last example of "3.4. Switch nodes with several conditions", but connect the outputs to different charts.
    Best regards
    stephane.legargeant
    Hello
    Best regards
    EDokm
    EDokmAuthor
    Your reply solved my problem. Thanks.
    mƎALLEm
    Is that a TouchGFX subject related?
    EDokm
    EDokmAuthor
    No. It is not TouchGFX related. I am trying to control a Permanent Magnet Synchronous Motor (PMSM).
    mƎALLEm
    Ok then the thread needs to be moved to the correct Forum.
