afshinkh
why my motor can't run more than rpm that select by motor profiler, how can run motor faster than motor profiler range select.
GMA
Dear afshinkh,
We would like to sincerely apologize for the delay in replying to your post.
If your point is still pertinent, you can set, in same motor profiler interface used for setting "Pole Pairs" number, you can also set "Max Speed".
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
