JBrin.3
We’re building a motor controller and would like the Altium project files for the EVSPIN32F06Q1S3 evaluation board.
The motors (being controlled) will eventually be used in a man-rated system. We know this EVSPIN32F06Q1S3 reference design is for unmanned systems like drones, but we plan to start here. Do you know of a chip and reference design that is better suited to man-rated flight hardware?
Each of our 4 motors uses (maximum) 15kW at 200VDC, hopefully 100A. Each motor has 3 motor controllers configured in a fail-over cluster. So 12 motor controllers per aircraft.
