Sep 4, 2023 9:30 AM UTC
want to check with CTM007V1 instead of CTM006V1
Hi all,
I'm currently having CTM007V1 driver board for motor control application. the control board is stm302r8 MCU and the driver board is STEVAL - TTM001V1. can i use modify the CTM006V1 firmware and replace it with CTM007V1 firmware?
Regards, Siva.
    Gael A
    Gael ABest answer
    Sep 14, 2023 7:31 AM UTC
    Hello SivaVishnu09,
    You can compare the schematics of both CTM006V1 and CTM007V1 driver boards on our website to check if there is any major modification that would not allow you to run a CTM006V1 firmware on a CTM007V1 driver board.
    If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
    Gael A
    Gael ABest answer
    Hello SivaVishnu09,
