SLori.1
Using timer 3 to read hall sensors
I’m trying to use the timer3 ch1 ch2 ch3 of stm32g4 to read the hall sensors of motor but selecting this config under workbench 5.y. the motor doesn’t work. The default hall sensors timer is timer2. Any idea?
cedric H
Hello @SLori.1​ ,
unfortunately, I can not provide you more information than one present in the specification available here for the board :
https://www.st.com/resource/en/data_brief/x-nucleo-ihm16m1.pdf
And here for the STSPIN830 :
https://www.st.com/resource/en/datasheet/stspin830.pdf
So :
IOUT,RMS Continuous power stage output current (each bridge) 1.5 Arms
Cedric
