Unable to write to RAW Structur in MC Motor Pilot
I am trying to write to SPEED_RAMP using the Registers tab in MC Control Pilot, however I get the following error:
ASPEP_RESP ERROR:ERROR_BAD_RAW_FORMAT
I am writing the data as follow for example: 6000;500
Can someone help me find the right synthax?
Thank you
Fabrice LOUBEYRE
Fabrice LOUBEYREBest answer
Hi AnthonyK, unfortunately this RAW format write feature into the Register Tab is not supported by the MCSDK Motor Pilot tool. You can only change SPEED_RAMP values from the Application/Speed Ramp boxes.
Best Regards.
Fabrice
Fabrice LOUBEYRE
Best Regards.
Fabrice
