LucasC
Hello Oleg,
Yes you can use the TrueStudio IDE by selecting it (check the attached PNG file to see all the supported IDE) when you generate your project with the Workbench. Once your project is generated, you can open it with the TrueStudio IDE by specifying the folder created by the Workbench named TrueStudio located at the place you have saved your project.
Regards.
Lucas
Laurent Ca...
Senior III
The question has been set only to the "STM32 Motor Control" topic (the question is only about the STM32 MC SDK).
Best regards
