The steps required to initialize the STSPIN830 motor driver
I'm currently working on a project using the IHM16M1 expansion board, and I would like to know the steps required to initialize the STSPIN830 motor driver
cedric H
Hello @issihaam,
The best advice I can give you is to use the MCSDK available on st.com and to generate a project using an IHM16M1.
The MCSDK will generate a project with full sources, and you will be able to understand everything.
Cedric
GMA
Hello @issihaam,
Did you generate an MCSDK project, and were you able to configure your IHM16M1 board?
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
