Nov 2, 2026 8:35 AM UTC
STSPIN948: How should LSS1B/LSS2B and SENSEB be connected when bridge B is unused?
We are using the STSPIN948 in dual independent full-bridge mode, with only bridge A driving a motor.
Bridge B is unused, and OUT1B/OUT2B are left unconnected. EN/nFAULTB is held LOW to keep these outputs in the high-impedance state, as specified in Table 9 on page 13 of the STSPIN948 datasheet.
Could you please confirm whether LSS1B, LSS2B, and SENSEB should be connected directly to GND or left unconnected in this configuration? Please also advise on the recommended connections for REFB and TOFFB.
Peter BENSCH
Nov 2, 2026 11:58 AM UTC
Welcome ​@Nguyen Thai Binh Duong, to the community!
Instead of letting the second full bridge run idle, you could also operate the two full bridges in parallel, which would reduce conduction losses (see datasheet, section 5.4.2).
However, if there is a reason not to do that, the datasheet does not explicitly specify how to terminate an unused bridge. With EN/nFAULTB held low and OUT1B/OUT2B left unconnected, it is recommended to connect SENSEB to ground rather than leaving it floating and maybe to connect LSS1B and LSS2B to power ground.
Do not leave REFB floating; connect it to a stable voltage within the specified 0.1V to VDD range.
TOFFB is a digital output, so leave it unconnected for the unused bridge.
Hope that helps?
/Peter
