STSPIN32G4 Trace Pins
I want to use the Trace Interface on the STS32PING4, but I can't seem to find the correct Pins for it. I have found a general Overview of where the Pins would be located in the STM32G431 here (PE2-PE6):
https://www.st.com/content/ccc/resource/training/technical/product_training/group0/c9/b9/a2/df/3e/80/45/59/STM32G4-System-Debug_DBG/files/STM32G4-System-Debug_DBG.pdf/_jcr_content/translations/en.STM32G4-System-Debug_DBG.pdf
But since the STM32G431 is integrated in the STSPING4, I don't know the mapping. Also in the Datasheet in the STSPING4, I can't find the Pin names TRACECK and TRACED0-TRACED3.
Greetings
dmuth
GMA
GMABest answer
Hello @dmuth,
Pin mapping is available in the STSPIN32G4 Datasheet under the "4 pin description" chapter.
PE2 to PE6 TRACE feature pins are not included in the STSPIN32G4 package.
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
GMA
GMABest answer
Hello @dmuth,
dmuthAuthor
Thanks for the clarification. I thought the trace pins would be available, but just not documented in the datasheet. Then we have to figure out another way for tracing.
