frankers
stspin32g4 and cube ide
hello st community!
I installed today
STM32CubeIDE Version: 1.17.0 Build: 23558_20241125_2245 (UTC). I want develop the firmware for a motor controller with the stspin32g4 mcu. i cant select this mcu in the target selector for the new project.
why did the people at st.com not have this mcu in the target selector?
what is a work around? i already run a serach for updates but it came back with no new updates.
should I select a G431 mcu? but I think the pin config will be different then. i have 5 mcu stspin32g4 here.
and the datasheet look like they are perfect for a small esc because the stspin32g4 with 170MHz has enough power to run FOC. and the BOM and pcb is small.
thank you if you can help me
Frank
Andrew Neil
Andrew NeilBest answer
See the 'Tools & Software' tab on the Product Page:
https://www.st.com/en/motor-drivers/stspin32g4.html#tools-software
It recommends X-CUBE-MCSDK - the STM32 Motor Control Software Development Kit (MCSDK:(
https://www.st.com/en/embedded-software/x-cube-mcsdk.html
Andrew Neil
