kulfi27
STM32G474 Hall sensor
Hello, I have a question regarding the use of the timer function xor input for the hall sensor in the BLDC motor, how do I read the first rotor position to start, then I understand that each timer interrupt changes the commutation.
Laurent Ca...
Senior III
The question has moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 SDK).
Best regards
Laurent Ca...
