STM32 Nucleo FOC adn 6-step motor control firmware
I'm just getting started with the above kit - first step was to reprogram the board to blink the LED! Now I'd like to controlling the motor. I see instructions to reprogram the .bin file, but I was expecting to see an example program with source code - am I incorrect to assume this?
    SRedd.5
    Senior III
    Try installing MCSDK 6.2.0 work bench for generating the source code for the motor application. It will generate the .hex file to flash in the board.
