Jakub Grajciar
STM workbench failed to connect control board
Posted on November 11, 2017 at 09:01
Software: ST Motor Control Workbench V4.3.0.16508
MCU: STM32F051C6T6
Phenomenon:  use serial port connect to MCU always fail. Some times can connect to MCU, but lose connection soon: Error msg: 'Communication is closed. the board doesn't response correctly' Even use baudrate 9600, get the same result.3
Laurent Ca...
Senior III
The question has been moved from the "Motor Control Hardware" section to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
