STEVAL-ESC001V1
I am working with the following tool versions:
  • MC Workbench: v5.4.8
  • STM32 Firmware Package: v1.11.3
  • STM32CubeMX: v5.6.1
Since I don’t have the Bull Running C1700KV motor, I’m using a 900KV motor with a 6S battery. I’ve already run the profiler, obtained the motor results, and entered those parameters into MCSDK.
My question is: Which additional parameters should I adjust to generate reliable firmware for this setup?
Senior III
What do you mean by additional parameters? The latest version of MCSDK is 6.4.
aj8791Author
MCSDK 6.4 is not working for STEVAL-ESC001V1
GMA
Hello @aj8791,
STEVAL-ESC001V1 and Bull Running C1700KV motor use case operates in 6-step mode with MCSDK version 6.4.1.
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
