Stepper Control with l6474
@Peter BENSCH . I am working on a project. In which i need to control Stepper motor using X-Nucleo-IHM01A1 Sheild. Currently i'm using STM32G431RB Nucleo-64 board for this and in future will use STM32F103. I've download X Cube SPN1 for basic working. But i think it does not support boards like (STM32G4 and STM32F103). How can i change X Cube SPN1 Library to make workable or any Solution for making L6474 to work with STM32F103 ?
Moreover, I successfully run Stepper motor with STM32G431RB in Arduino IDE same version of this library.  Link of library is attached. https://github.com/stm32duino/X-NUCLEO-IHM01A1.
Cristiana SCARAMEL
Hello @SannanAli,
You can use the drivers for other STM32 MCUs found in the BSP/X-NUCLEO-IHMxx folder as starting point, and adapt the calls to the HAL libraries for use with the STM32F103.
"If you feel a post has answered your question, please click ""Accept as Solution"""
SannanAliAuthor
Can you explain the above procedure a little bit more. Like How to use BSP for STM32F103.  I do not know what's the procdure to make X-CUBE-SPN1 or SPN3 to work with STM32F103C8T6. Any document for implementing X-CUBE-SPN1 or other software expansion package for different board. That would be great to help.
Peter BENSCH
Do you have a specific board in mind when you think of STM32F103V8T6? Perhaps a Blue Pill board?
Please upload a photo of it.
/Peter
SannanAliAuthor
Yes. It's Blue Pill Board STM32F013
SannanAliAuthor
I have Changed board from bluePill, to STM32F103V8T6 Controller. X-CUBE-SPN1 mostly works with Nucleo Board. I want to control stepper motor with STM32F103V8T6 . What's the procdure to make X-CUBE-SPN1 or SPN3 to work with STM32F103V8T6 . Any document for implementing X-CUBE-SPN1 or other software expansion package for different board. That would be great to help.
