RReic.2
Startup failure without mechanical load
we are using Sensorless FOC with open loop starting of the BLDC motor. The Motor is starting reliably under normal and heavy load conditions. But without load the I got startup failure. Any idea what paramter should be checked or improved?
MC SDK 6.2
PLL Observer
GMA
Hello @RReic.2,
For FW Error handling, refer to User Manual documentation available through "Workbench tool">About>Documentations>Documentation>"User manual" tab, "Firmware errors" link.
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
