Thp.1
ST32cubeIDE build error with code generated by Motor control MC_SDK
Dear all,
I used MotorControl Workbench 5.4.3 to generate code (toolchain st32cubeIDE) and use st32cubeIDE 1.3.0 to build code. If my project is Nucleo IHM001 kit, code build successful. When my project is STEVAL SPIN3202, code build error (collect2.exe: error: ld returned 1 exit status
make: *** [makefile:46: Steval_spin3203_test.elf] Error 1).
Build console:
11:45:45 **** Incremental Build of configuration Debug for project Steval_spin3203_test ****
make all
arm-none-eabi-gcc -o "Steval_spin3203_test.elf" @"objects.list" -l:libmc-gcc_M0.lib -mcpu=cortex-m0 -T"D:\newpro\Arm\Foc_encoder\firmware_FOC\Steval_spin3202\Steval_spin3203_test\STM32CubeIDE\STM32F031C6TX_FLASH.ld" --specs=nosys.specs -Wl,-Map="Steval_spin3203_test.map" -Wl,--gc-sections -static -L../../MCSDK_v5.4.3/MotorControl/lib --specs=nano.specs -mfloat-abi=soft -mthumb -Wl,--start-group -lc -lm -Wl,--end-group
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: Steval_spin3203_test.elf section `.text' will not fit in region `FLASH'
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: Steval_spin3203_test.elf section `._user_heap_stack' will not fit in region `RAM'
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: region `RAM' overflowed by 8 bytes
c:\st\stm32cubeide_1.3.0\stm32cubeide\plugins\com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.7-2018-q2-update.win32_1.0.0.201904181610\tools\arm-none-eabi\bin\ld.exe: region `FLASH' overflowed by 22948 bytes
"make all" terminated with exit code 2. Build might be incomplete.
11:45:53 Build Failed. 1 errors, 0 warnings. (took 7s.493ms)
How can I fix this error?
Thank you.
Laurent Ca...
Senior III
Dear Thp.1
Do you have still this problem to solve?
Best regards
Laurent Ca...
Laurent Ca...
Senior III
Dear @Thp.1​
I guess you don't have to solve this problem anymore, therefore I consider this post closed.
If not, feel free to reopen it by posting a new answer.
Best regards
Laurent Ca...
