杨REN.1
ST Motor Control Workbench can't generate example code for STEVAL -SPIN3202,what can i do to fix this error?
0693W00000GXLHDQA5.pngthe message shows need to download FW.G4.1.11.2 firmware, but the latest firmware is 1.4.0, what's wrong with this ? any one can give some suggestion? thanks a lot.0693W00000GXLGyQAP.png
cedric H
Hello @�?� REN​ ,
Your issue is strange, the SPIN3202 is based on a STM32F0, not on a STM32G4.
The firmware required is the stm32F0 HAL version 1.11.2
You can try to install it directly from cubeMX. or if it does not work, it is available to download here :
https://www.st.com/en/embedded-software/stm32cubef0.html
Cedric
