ST intranet updater server is unknown: mcucrossselector.codex.cro.st.com
I am currently encountering an issue while configuring the Motor Control Workbench. Upon completion of the configuration, I receive an error stating "ST Intranet Updater Server is unknown: mcucrossselector.codex.cro.st.com." Additionally, the compilation process in Motor Control Workbench results in "Compiled with errors."
I am using STM32 Cube IDE to upload the program. Could you please provide guidance on whether this server error is something that needs attention, or if it can be neglected?
Thanks in Advance
Gael A
Gael ABest answer
Hello suhas1,
The issue you are facing has been resolved in newer MCSDK version, please consider upgrading your setup to MCSDK 6.2.1.
However, as I see it on your picture, it seems that your project has been generated completely and should be working fine.
If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
Gael A
Gael ABest answer
Hello suhas1,
suhas1Author
Thanks for your reply it was helpful the error is not showing now and I'm using latest Cube MX file.
