source cord를 제공해 주실 수 있나요?
안녕하세요. 저는 개인 개발자 입니다. 이번에 steval ctm051 보드를 구입해서 srm 을 공부하려는 데 소스코드를 제공할 수 있다고 해서 어떻게하면 소스코드를 제공 받을 수 있는지 알려 주시면 감사하겠습니다.
Please note that the forum is English-speaking, which is why I have machine-translated your question into English:
Hello. I am an individual developer. I recently purchased the steval-ctm051 board and would like to study SRM. I was told that the source code can be provided, so I would appreciate it if you could let me know how I can obtain the source code.
Peter BENSCH
Peter BENSCHBest answer
Welcome @dentistkim, to the community!
You probably made a typo and meant the STEVAL-CTM015V1?
I had already answered the same question here, which has not changed since then.
Hope that helps?
Good luck!
/Peter
Peter BENSCH
Hope that helps?
Good luck!
/Peter
