Karthik DM
Six-Step BLDC Control Complimentary Switching Issue
Currently, I'm working with BLDC motor controller development. I used complementary switching logic to control my MOSFET. Here, the motor is not starting at less duty cycle, the motor is starting only at 70percent duty cycle. and more noise also coming
anybody, please help me how to solve this issue.
Thank You.
Commutation code is:
case 1:
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_1);
HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_1);
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_2);
HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_2);
HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_3);
HAL_TIMEx_PWMN_Stop(&htim1, TIM_CHANNEL_3);
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_1, duty_cycle);
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_2, 0);
TIM1->CCR1 = duty_cycle;
TIM1->CCR2 = 0;
break;
case 2:
HAL_TIM_PWM_Start(&htim1, TIM_CHANNEL_3);
HAL_TIMEx_PWMN_Start(&htim1, TIM_CHANNEL_3);
HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_2);
HAL_TIMEx_PWMN_Stop(&htim1, TIM_CHANNEL_2);
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_3, 0);
TIM1->CCR3 = 0;
break;
case 3:
HAL_TIM_PWM_Stop(&htim1, TIM_CHANNEL_1);
HAL_TIMEx_PWMN_Stop(&htim1, TIM_CHANNEL_1);
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_2, duty_cycle);
TIM1->CCR2 = duty_cycle;
TIM1->CCR3 = 0;
break;
case 4:
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_1, 0);
TIM1->CCR1 = 0;
break;
case 5:
//__HAL_TIM_SetCompare(&htim1, TIM_CHANNEL_3, duty_cycle);
TIM1->CCR3 = duty_cycle;
TIM1->CCR1 = 0;
break;
case 6:
TIM1->CCR2 = 0;
break;
Javier1
Principal
take a look at https://community.st.com/s/question/0D53W00000iC3sUSAS/how-to-setting-tim-chxchxn-for-six-step-bldc-motor-control
You dont want to Stop the pwm you want to disable specific pwm channels.
hit me up in https://www.linkedin.com/in/javiermuñoz/
Karthik DM
Hello Javier
Thanks for your kind reply,
Can you please suggest to me how to disable a specific PWM channel?
Thank You.
