MMila.3
Sampling 3 phase current with only 1 ADC
In motor control pack P-NUCLEO-IHM001, microcontroller is STM32F302R8 which has only 1 ADC.
The motor drive has option to use 3 current shunts.
By analyzing the datasheet, ADC does not have multiple sample & hold circuits.
So, how would it be possible to sample 3 phase current with this mcu?
cedric H
cedric HBest answer
We sample only two phases and reconstruct the third one. We select the two phases to sample according to the electrical position of the rotor.
With the configuration with one ADC, the two sampling are executed in a row.
Cedric
Laurent Ca...
Senior III
Adding of "Motor Control Hardware" topic.
Best regards
cedric H
cedric HBest answer
Cedric
MMila.3
MMila.3Author
Thank You for the answer. Now I understand that it's ok to do 2 samples 1 after another.
