Precise Motion Control for BLDC Motor
I have following Harware configuration:
- X-NUCLEO-IHM16M1 (STSPIN830)
-  NUCLEO-L476RG
BLDC Motor with three analog hall sensors
I'd like to be able to configure your Motor workbench to do the job.
Questions:
-   Are the boards X-NUCLEO-IHM16M1 + NUCLEO-L476RG compatible ? I suppose yes
-   How  would you configure position control for analog Hall sensor with your motorworkbench ?
Do you have any api or docs which might help ?
Many thanks
Younes
    GMA
    Hello @Youni,
    Please, refer to the position control application note.
    As mentioned, this feature is only available with a PMSM motor with quadrature encoder (with index signal).
    APIs are also described.
    If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
