need a 5kW motor driver board
Hi all,
       I'm Siva, and i need a BLDC motor driver to run a 5kW motor. please suggest me in buying out the right driver board. the voltage needed for the motor is 48 volt and the current needed will be 180A.
    Zied b.Best answer
    I suggest the St Mc Suite tool, which lists you the Motor Control compatible boards with the details, Here is the link : https://www.st.com/st-mc-suite/home/
    - Click on - Start -> Engine Control Solution
    - select the motor type (BLDC)
    - select the algorithm
    - then choose your board in Power Board
    The STEVAL-CTM009V1 board can meet your expectations.
    "If you agree with my answer, please accept it by clicking on ""Accept as solution""."
    also a motor driver which is capable of doing 6 step commutation and FOC advanced algorithms.
    Zied b.Best answer
