??Fil
Sep 25, 2018 2:00 PM UTC
MotorControl Workbench 5.2.0 does not detect STM32CubeMX
Hello all. I tried finding a solution on all the resources I can think of, tried uninstalling/ reinstalling the Cubemx and MotorControl Workbench, following the suggested order (first install cubemx, run it at least once before launching the workbench) to no avail. I cannot generate code sin MotorControl Workbench 5.2.0 does not detect STM32CubeMX version 4.27.0. Your help would be much appreciated.
yxie.9
Sep 26, 2018 2:22 AM UTC
if i change the cubeMX repo path,MotorControl Workbench 5.2.0 will not generate the right code.does you change the repo path
??Fil
??FilAuthor
Sep 26, 2018 7:02 AM UTC
Hello ly11262255204...
repo path remains default which in my case is : C:/Users/pc/STM32Cube/Repository/
Laurent Ca...
Senior III
Jun 22, 2021 9:13 AM UTC
The question has been moved from the section "Motor Control Hardware" to the "STM32 Motor Control" section (the question is about the STM32 MC SDK).
Best regards
