Motor speed uncontrollable
I am using STEVAL-ESC001v1 and a2212/10t 1400kv motor. While giving it supply and reference signal, the measured speed keep on increasing and the actual speed of motor as well. Also, motor_state stucked at START but motor still running. Please help.
tejas_ampAuthor
Reply ??
GMA
Hello @tejas_amp,
Did you used MC motor profiler for your motor?
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
tejas_ampAuthor
Thanks for the reply. I had used Motor Profiler, it showed "Profiling taking too much time", following the ST Documentation, I tried altering max RPM, max Current values but didn't find any way. Please, please help in figuring this out.
GMA
Hello @tejas_amp,
You can refer to this thread for this topic.
