Motor forward/reverse transition issue in ST Motor Pilot
Hi all,
I’m currently using the EVSPIN32G4 development board for a drone project. I’m controlling motor forward and reverse using ST Motor Pilot.
I’ve noticed that when switching from forward to reverse, there’s a short pause before the motor starts spinning in the opposite direction.
Is there a way to implement a seamless transition between forward and reverse motion so that the motor can switch direction without this stop?
Thanks in advance for your guidance!
STuser2Best answer
Senior III
STuser2Best answer
Senior III
