DigitalMonk123
This error usually means the COM port is open but the board isn’t responding—ensure the correct COM port and baud rate are selected, and that the firmware on your STM32 is running with Motor Control UART enabled. Also check cable, drivers, and that no other software is using the same port.
GMA
Hello @dineshsharma2025,
Check also Baudrate speed (set to 115200 on your snapshot).
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
