Motor Control Protocol
I am using Nucleo L476RG for controlling BLDC motor. In the FOC control, i need to change the motor ID in the code. What is the procedure to change motor ID??
GMA
Hello @deadlock,
What do you mean by "change motor ID"?
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
deadlockAuthor
I have 4 motors connected on same RS485 Bus, i want to address particular motor by Motor ID to control motors individually. Let me know  how to address this issue.
GMA
Hello @deadlock,
STM32L4 series MCSDK firmware is only capable of controlling one motor at a time.
deadlockAuthor
Yes, I have connected 4 numbers of STML4 series motor on single RS485 protocol. I want to send RPM command to each motor individually. Please let me know how to modify the code so that i can control motor through ASPEP protocol.
BT.3
I am also trying to the same. @GMA Please suggest
