TB_it
Most STM32 timers have four (or more) channels. A quadrature encoder requires two channels. Is it possible to use a single timer on an STM32 for TWO quad encoder counters? If not, can the other channels be used to generate PWMs for driving H-bridges?
I’m particularly interested in using a single STM32G4 for two 32 bit encoder counters, if that is possible?
KnarfB
KnarfBBest answer
No. Look at Figure 266 in STM32G4 Series RM0440 Reference manual. Only the first two timer channels are connected to the encoder interface (tim_ti1fp1, tim_ti2fp2).
and "Encoder interface mode acts simply as an external clock with direction selection. This means that the counter just counts continuously between 0 and the auto-reload value in the TIMx_ARR register (0 to ARR or ARR down to 0 depending on the direction)." . So, you cannot use the other channels for PWM.
KnarfB
KnarfBBest answer
TIM might have four channels, but only has ONE counter. So one TIM per encoder, Ch3/Ch4 not usable
TB_it
TB_itAuthor
got it, thanks. STMcube didn't exactly make this matter clear (the maintainer of STMcube might want to adjust that...)
