MCSDK HRTIM
Does MCSDK support hrtim?
    FouadB
    FouadBBest answer
    Hello Iskan,
    The STM32 Motor Control Software Development Kit (MCSDK) does not utilize the HRTIM (High Resolution Timer). For our motor control, only the advanced-control timer (such as TIM1) is required to generate the output PWM waveform.
    Best regards
    If you agree with my answer, please accept it by clicking on 'Accept as solution'.""
    iskanAuthor
    I want to use hrtim to replace time1 in the ST motor library code, what should I do?
    Issamos
    Hello @iskan
    Can you add a few details to your question. I'm not sure I understand what you want to know.
    Best regards.
    II
    iskanAuthor
    FouadB
    Hello Iskan,
    Please find here an introduction about HRTIMER capabilities and the mode suitable for motor control. (from p17, 18, 19): https://www.st.com/resource/en/product_training/STM32G4-WDG_TIMERS-High_Resolution_Timer_HRTIM.pdf
    You can use CubeMx to activate and set up the HRTIMER and subsequently update the FW FOC (MCSDK).
    Best regards
    FouadB
    FouadBBest answer
    Hello Iskan,
    Best regards
