MCSDK 6.4.2 VBUS sensing clarification required
I need some information regarding VBUS sensing configuration in MCSDK. Here’s the relevant screen when editing a board:
I am confused because R1, R2 and R3 are not marked on the schematic so don’t know what they refer to. My guess is that R1 is the top resistor in the voltage divider, R2 is the bottom one? But this is just a guess. Maybe R3 is series to the MCU pin? It’s nowhere to be found on the picture.
Also please explain the need for an explicit “Bus Voltage Divider” parameter. Isn’t this redundant provided that it’s determined by the resistors? Or is this something else? What’s the idea here?
Thank you, Szabi
