AndrewSibiryack
It is not clear where the value of SPEED_LOOP_FREQUENCY_HZ is defined.
Hi!
Help!
When creating a position control project in the MC SDK using NUCLEO-F446RE and X-NUCLEO-IHM08M1-3Sh when compiling to KEIL, an error occurred.
Thank you in advance!
VFerr.2
VFerr.2Best answer
Replace by POSITION_LOOP_FREQUENCY_HZ in all files. It's a bug.
VFerr.2
VFerr.2Best answer
Amel NASRI
Thanks @VFerr.2​ for sharing the solution.
@cedric H​ , could you please take care to implement the fix?
-Amel
cedric H
Hello @Amel NASRI​
This is a known issue already handled in the following thread
Cedric
AndrewSibiryack
Thanks! Everything worked out!
