Senior
Is there any sample code to drive bldc motor in sinusoidal control?
Hi All.
​Does anyone know about a simple sample code to drive bldc motor with sinusoidal control?
I only want to know the way how to setting PWM and update the PWM output.
MCSDK’s output sample code is hard to use and understand, it take time. ​Something like the device peripheral sample code will suffice.
Igor Cesko
Igor CeskoBest answer
Hi Kenji ,
Please try to study Timer example in STM32Cube FW: "\STM32Cube_FW_G4_V1.4.0\Projects\NUCLEO-G474RE\Examples\TIM\TIM_PWMOutput". Or examples "TIM_DMA", "TIM_DMABurst", ... (some others).
Those examples are about PWM control. Maybe this can help.
Igor
Igor Cesko
Hi Kenji ,
Igor
Explorer
Hello @Igor Cesko & @Kenji1 ,
I am unable to find the example code. Could you please send it ?
Monica
mƎALLEm
Kenji1Author
Senior
Dear Igor-san
Thank you for the information.
I will check it.
