Is STEVAL-ESC002V1 compatible with PX4 firmware?
Can STEVAL-ESC002V1 be applied in a electronics of quadcopter? For example, is it possible to connect to betaflight FCU or Pixhawk?
    Zied b.Best answer
    Hello @LukeBaek
    We would like to sincerely apologize for the delay in replying to your post.
    If your point is still pertinent, You can find the documentation to use the STEVAL-ESC002V1 at this link : https://www.st.com/resource/en/user_manual/um2518-getting-started-with-the-stevalesc002v1-electronic-speed-controller-reference-design-stmicroelectronics.pdf.
    It looks like it's possible to use this board to control a motor with an incoming PWM signal, that signal could be coming from your flight controller.
    "If you agree with my answer, please accept it by clicking on ""Accept as solution""."
    Zied b.Best answer
    Hello @LukeBaek
