DLee.10
In ST Motor Control Workbench Project generation What is the massage " StateRcvOpen_Cte Bad Token : ) "
2022-05-20 17:13:48,707 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,706 [INFO] DependencyParser:915 - This component is not compatible with the current MCU : [1617735864348, 1617735864350, 1617735864358]
2022-05-20 17:13:48,707 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,706 [INFO] ThirdPartyModel:556 - Component with status : MCU_INCOMPATIBLE for condition : MotionPE Condition id : 1617735852453
2022-05-20 17:13:48,707 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,706 [INFO] ThirdPartyModel:556 - Component with status : MCU_INCOMPATIBLE for condition : MotionSD Condition id : 1617735852457
2022-05-20 17:13:48,707 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,707 [INFO] DependencyParser:915 - This component is not compatible with the current MCU : [1602416925337]
2022-05-20 17:13:48,708 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,707 [INFO] ThirdPartyModel:556 - Component with status : MCU_INCOMPATIBLE for condition : GFX01M1_Condition id : 1602416925322
2022-05-20 17:13:48,708 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,707 [INFO] DependencyParser:915 - This component is not compatible with the current MCU : [1602416925337]
2022-05-20 17:13:48,708 DEBUG [LineInfo_to_exitCode.log_LineInfo] 2022-05-20 17:13:48,707 [INFO] ThirdPartyModel:556 - Component with status : MCU_INCOMPATIBLE for condition : GFX01M1_HelloWorld_Condition id : 1602416925324
2022-05-20 17:13:48,717 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,718 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,719 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,720 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,931 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,932 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,933 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,934 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,935 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,936 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,937 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,938 ERROR [LineInfo_to_exitCode.log_LineInfo] StateRcvOpen_Cte Bad Token : )
2022-05-20 17:13:48,997 ERROR [LineInfo_to_exitCode.log_LineInfo] StateInit_Cte Bad Token : )
2022-05-20 17:13:48,998 ERROR [LineInfo_to_exitCode.log_LineInfo] StateInit_Cte Bad Token : )
2022-05-20 17:13:48,999 ERROR [LineInfo_to_exitCode.log_LineInfo] StateInit_Cte Bad Token :
2022-05-20 17:13:49,000 ERROR [LineInfo_to_exitCode.log_LineInfo] StateInit_Cte Bad Token :
zcame.1
hello, i get the same issue, can you please tell me how to solve
