If Motor Profiler will open source?
I often use Motor Profiler to identify motors.But it is not good.
Sometimes my motor cannot be recognized when using 48V and I have to reduce the supply voltage to 36V.
Here I would like to ask whether it will be open sourced. I want to understand the principle of identifying the motor and improve it.
    Zied b.Best answer
    Hello @gtop.1
    To answer your main question, there are currently no plans to make the Profiler opensource. to let me better understand your problem to help you find a solution: Can you tell me which version of the MCSDK you are using? and which power board and control board do you use ?
    Thank you
    "If you agree with my answer, please accept it by clicking on ""Accept as solution""."
    Zied b.Best answer
    Hello @gtop.1
    Thank you
    gtop.1Author
    Hello.
    I use 5.Y.4 MCSDK and NUCLEO-F302R8+X-NUCLEO-IHM08M1 3Sh,with 48V 471W pmsm motor. The motor keeps turning and cannot identify the Ke.
    Can you try with the new version of MCSDK 6.2, and tell me if it works better. To use the profiler on 6.2 you must generate a profiler firmware, for this please follow the MCSDK documentation.
