Tejashree
I want to use Example from MC WB for BEC-STM32G431CB.How define user code?
I used motor profiler .Saved the paramters and then while using the examples Imported those paramters.I used following as user code in main.c in while(1):
 if( MCI_GetSTMState() == RUN )
  MCI_ExecSpeedRamp(MCI_EXECSPEEDRAMP,1000,2000);
 MCI_StartMotor(MCI_EXECSPEEDRAMP);
else;
MCI_StopMotor()
How to start motor with user code in example from MC WB?
cedric H
cedric HBest answer
Ok, So you want to start your motor at power on and stop it after 5 seconds.
Use the API provided in mc_api.h as shown in the exemple below (in your main.c) :
 /* USER CODE BEGIN 2 */
MC_ProgramSpeedRampMotor1( (int16_t) (1000/6), 10 ); /* Apply a ramp to reach 1000 RPM in 10 ms - 1000 RPM = 1000/6 0.1 Hz */
MC_StopMotor1(void);
  HAL_Delay(5000); /* wait for 5 seconds*/
 /* USER CODE END 2 */
 /* Infinite loop */
 /* USER CODE BEGIN WHILE */
 while (1)
  /* USER CODE END WHILE */
  /* USER CODE BEGIN 3 */
 /* USER CODE END 3 */
Cedric
cedric H
Hello @Tejashree​
I am not sure I understand what do you want to do.
Could you describe on which events do you want to start and stop your motor.
Cedric
Tejashree
TejashreeAuthor
i just imported the example with parameters from motor profiler.Now i just want to run the motor with user code.Example:Run motor at 1000rpm for 5sec
Tejashree
TejashreeAuthor
I am not able understand the motor_interface.h file properly to use the functions.Can you suggest me how can i run the motor by defining user code?
cedric H
cedric HBest answer
 /* Infinite loop */
 while (1)
Cedric
