hchon.1
how to set p-nucleo-ihm001 to be Single shunt to active BR2804-1700kV.
follow the quick-start, i can set three shunt to active BR2804-1700kV.
but when i use single shunt, it always occured overload current.
when i set single shunt, i set the settting as the appendix
Gael A
Hello hchin.1,
First of all, we would like to apologize for the delay in replying to your post.
If your point is still relevant, I would like to ask you if you have moved the jumper related to 1-Shunt configurations on the IHM07. They normally are set on 3-Shunt configuration, this may be the issue you are facing.
If you agree with my answer, please consider accepting it by clicking on 'Accept as solution'.
