Oct 15, 2025 2:24 PM UTC
How to fix the center-aligned problem of the PWM signals?
Hello Everybody,
Here are the software and boards in this case:
1. MC workbench 6.4.1
2. STM32 FW V1.28.2
I’m running the code generated by ST MCSDK and noticed that the waveforms on the microcontroller’s U-phase and V-phase channels (see pins Ch. U and Ch. V in picture 2) are not center-aligned—there is a slight offset (see picture 1: the center of the blue waveform is shifted a little to the left relative to the yellow one). How can I fix this? I suspect this mismatch is causing noticeable acoustic noise while the motor is running.
How can I fix the problem? Thank you!
federico.rodighiero87
Explorer
Nov 11, 2025 8:04 AM UTC
Yes, if no shifting techniques are used, the PWM signals are center-aligned.
HW/FW Motor Control Engineerhttps://www.linkedin.com/in/federicorodighiero/
GMA
Oct 15, 2025 3:43 PM UTC
Hello @DF_MC,
For single-shunt topology, a phase shift is applied as described in the Single-shunt with phase-shift current sensing overview chapter of the user manual available through Workbench tool > About > Documentations > Documentation > User manual.
If you agree with the answer, please accept it by clicking on 'Best answer'.Best regards.GMA
DF_MCAuthor
Oct 16, 2025 2:54 AM UTC
Hello, @GMA
Thanks for your reply. I am using the "isolated current sensor topology" (as shown in the picture below). Should I make any modifications to the generated code to fit my current configuration? Thank you!
