How to drive a motor with both encoder and hall?
- 4 replies
- 772 views
Hi there,
I have a motor support both encoder signals(ABZ) and hall signals(ABC) output.
But I checked the DEV Kit and the examples of MCSDK6. Most examples use only one of the position feedback sensors.
And for the MCSDK6 project, I can only configure the encoder and hall signal as a timer input. However, I DIY board can only support TIMER for the encoder and GPIO for the hall.
I am asking for help on how to configure the project so that I can use both the encoder and the hall sensor in the motor with my DIY board.
(I found a document named "Generation and use of Hall correspondence Table.pdf" by ST in Chinese. But I can't understand some details in this file. Is there anything more that can help me to understand this?)
Thank you for your help!
