Vijay Ganisetti
How to develop a random PWM for motor control using Nucleo F446RE MCU??
When motor is running at fixed frequency (30kHz), there is a slight noise. Hence, I want to see the varying PWM in runtime in order to minimize the noise
Javier1
Principal
What type of motor is it, brushed DC?
i suppose thats the PWM frequency?
What type: electromagnetic noise... instrumentation noise, actual sound?
If you want to introduce jitter in order to flatten the freq profile peak, you just need to change the ARR of your timer at runtime, i have never done this.
And in order to archieve this the "noise" doesnt need to be random, just needs to be evenly distributed around your main freq.
Noise comes from poor choices at the designing stage of your electronics(PCB), i would start looking there.
hit me up in https://www.linkedin.com/in/javiermuñoz/
Vijay Ganisetti
hi @Javier Muñoz​ ,
Yes, it is brushed DC motor. According to the motor parameters, motor control workbench suggests best operating conditions at 30kHz. i want to use random PWM rather than fixed PWM frequency in order to spread the frequency spectrum of the generated PWM.
Yeah i tried to update ARR of the timer using a function but its not working. Can you suggest any idea to update ARR in runtime?0693W00000GWIt7QAH.jpg
Javier1
Principal
TIM1->ARR=89;
 Maybe have some DMA loading the TIM ARR register constantly? from a lookuptable of values.
cedric H
Hello @Community member​ ,
Could you describe your setup, Power board, motor and Software ?
If I understand correctly you use a Brushed DC motor, and the motor control workbench ??
The motor control workbench provides FOC algorithm for brush less PMSM motor (three phases Brush less DC Motor can work too).
Cedric
