How to change the parameter  Minimum  frequency  in main.c
Hi All,
I need to change parameter  Minimum  frequency  "MIN_FREQUENCY_TH "  by main.c
not chage  in acim_vf_parameters.h
Please help me for advice.
BR,
Methee
    TDKBest answer
    #define MIN_FREQUENCY_TH 42
    Maybe.
    Hello @methee_c,
    Some context maybe?
    methee_cAuthor
    Dear  sarra.S,
    Thanks you,
    Ok, now i can setting  in main.c but can't set variable to float  function need to constant  float only.
    BR,
    Methee
    TDKBest answer
    Maybe.
    methee_cAuthor
    Dear  TDK,
    Ok, now i can setting but can't set variable to float  function need to constant  only
    BR,
    Methee
