LYang
LYangBest answer
:) You can measure the parameters. here is a construction video by ST:
 https://www.youtube.com/watch?v=XnGHpT96Ri4&list=PLnMKNibPkDnEgc7QwaabA5SKz5_4Mwz4e&index=2
LYang
LYangBest answer
oleg_sidorovich_1981
Is there AN for that video?
Cristiana SCARAMEL
Hi @oleg_sidorovich_1981​,
yes you can use the excel also for delta connection.
In both cases, the measurements is always made between two motor phases and the excel file translates the measures into an equivalent model that is unrelated to the actual motor phase connection.
"If you feel a post has answered your question, please click ""Accept as Solution"""
Laurent Ca...
Senior III
Adding of STM32 Motor Control topic.
Best regards
