Laurent Ca...
Senior III
Dear @Tore Kallevik​
Sorry for the late answer.
Do you have still this problem to solve?
And just in case, if not, do not hesitate to share the final solution you found. Thanks by advance.
Best regards
Tore Kallevik
Yes, I need to lock the rotor in a known posision in order to calibrate the zero position of my on-axis magnetic rotary position sensor (ams type AS5147U) with UVW hall commutation interface.
